Hi everyone! I hope this gets to Joe Reeves, if someone could pass this along, as he is the electric shift expert!
Quick Summary:
I bought a 1988 Larson 15' with a 1970 Johnson 60 hp, electric shift. Model 60ESL70B. Fixed the boat up, motor ran, and life was good. Had the usual lower end issues with it not shifting into N or R. drained the oil, milky. Didnt have a fast leak in the lower unit, so I would change the oil about twice a summer, and had no problems. Would shift, drive, and have fun with it.
Well, this past spring/summer i dropped the lower end and bought the lower end seal kit from iboats, to remedy the leaking issue. Also a new impeller. I used the parts diagram to figure out what was what. Put all new seals on, pressure tested the lower unit, and all is happy!
Put the lower unit back on last night, filled with oil, fresh gas and fired it up. Started perfectly. In Neutral on the start and prop not spinning = Good. Put it in forward, prop starts spinning in the forward direction = Good. Put it into reverse and no prop spin = Bad :grumpy:
I have checked the leads on the powerhead side for voltage. Forward no voltage on the green or blue leads = Good. In Neutral, 12 volts to the green and no volts to the blue = Good. In Reverse 12 volts to both the leads blue and green = Good. So I started to think I have a bad solenoid. But it ran perfect at the end of last season. So I checked the ohms on the solenoid leads. I had 5.8 ohms on green and 6.1 ohms on the blue lead. That leads me to believe the solenoids are good.
The only thing I can think of is that when putting the solenoids back into the lower unit after resealing, i am some how hampering the movement of one of the solenoids.?.
Which solenoid is moved for the reverse to work? upper or lower? They are on a rod system, not the spring system. How much is each solenoid supposed to move? the upper solenoid was pretty close to the top of the lower unit cover, and just below the wavy washer. Does this solenoid travel? Or just the lower one. I plan to drain the lower unit tonight and pull it off again. I just want to make sure that I put it back together correctly. I do have the parts diagram available in paper form from this website.
Any advice would be great!
Thanks Pros! i would be on the beach watching if ti wasn't for you guys!
Jonny Neal
-Big Tuna
Quick Summary:
Jonny Neal
-Big Tuna
