Boat was not used for two years, and I finally launched it this spring and have been using it every weekend since fishing down the jersey shore. Few things I need answered. On initial startup I prime the bulb till firm, then crank motor over. Sometimes I can get it started fine, other times I get the lean sneeze, and need to work the bulb and keep cranking till it fires. Leaving slip under slight throttle the motor seems like its running rough, with noticeable vibrations you can both feel and see. Twice this year I was entering the channel, and go to throttle up and cant get past 3000rpm. This is with be putting the throttle handle at WOT. Then after about a minute or so the motor wakes up and goes back to normal. Not sure what that is all about. Lastly, when warmed up, when drifting for fluke, every time I restart the motor I have to choke it up to idle then have to literally slam shifter in gear and take off quick or the boat will die. Finally when returning to slip, the boat sometimes stalls out goin in and out of gear while docking. This is a general overview of what I ve been experiencing. Overall it hasn't stopped me from enjoying the boat. I do all the work myself, and I am eager to learn about this motor. I did the water pump, LU lube and new plugs this spring. Thinking maybe my carbs may need a rebuild. I have owned the boat for 7 years, and have done nothing to the carbs. Also never change the inline fuel filter or messed around with the fuel pump, if there is one:facepalm: Anyways sorry for long post, but I needed to get this out there. Any help would be great!
