99chevyjoe
- Jul 23, 2013
- 2
Hello everyone,
Let me start with this: motor is a '96 Mercruiser MCM 5.7L Serial# OF789110. It has the Alpha One outdrive. I lost the block last winter to a deep freeze ( a month of about -10* to -25*). I had a hard time finding a replacement crate motor (that allowed me to keep both arms) that accepted a mechanical fuel pump, so I'm having to convert to an electric pump.
I'm trying to wire in an aftermarket fuel pump but I am missing a terminal on my starter solenoid. I understand that I need to wire this through an oil pressure switch (which I have), but I also have to have current supplied to the pump while cranking. The problem I'm having is that the starter I have (OEM and original) on my motor only has two terminals (Permanent Magnet gear reduction 200). The large terminal accepts the Big red(Bat +), the Orange(Alt.) and the red/purple(to Breaker then slave). The small terminal accepts the yellow/red(back from slave).
My question is can I use the small terminal(with the yellow/red) to supply power to the pump while cranking?
Thanks for any help in advance.
