dehphoenix
- Jul 23, 2013
- 2
There is a single red wire attached to a square block mounted on the relay. I disconnected the wire to clean the terminal and forgot to disconnect the battery. When I used a socket to tighten the nut on the terminal it contacted the body of the relay housing and sparks flew. Now when I turn the key I get no clicking, no instruments, no accessories. I can still short the other two terminals on the relay and turn over the engine. How can I find out what is wrong? blown fuse or did I mess up the relay?
