fish_or_die
- Mar 5, 2012
- 10
Hey guys, just picked up a 1987 Johnson 28spl that seemed to be in great condition, isn't that the way most of these threads start?
Anyway, the motor starts up instantly, but ran a little rough. Did a carb clean and rebuild, got a new fuel line, replaced the spark plugs, threw some seafoam in the tank and took it out to the lake.
On the lake, the motor starts up like a champ and purrs at idle. With the warming lever it revs freely up to the upper ranges with little hesitation. Throwing it into gear however, it bogs, acts like it's not getting enough gas and dies. We trolled around with it for a bit pushing the throttle to the point where it would start to stutter and took it back a bit.
After a while the motor started to lunge so we gave it more gas. this time it didn't die, but kept going at low rpm and lunging into higher RPMs intermittently. Those lunges came closer and closer together until it seemed something was breaking loose and we planed out a bit, not quite up to full revs though. We ran with it for a while and then stopped to check the spark plugs. It never got up on plane again, still choking out when we took it past idle.
Any ideas?
Any ideas?
