tone_searay185
- Jul 2, 2013
- 3
I have a 1991 Mercruiser 4.3 2 bbl that isn't getting gas to the carb. The last owner didn't properly treat the gas and it sat for 8 months with 1/4 tank of gas.
I added Stabil and 10 gallons of gas, then I replaced the in-line filter and the in-carb filter (which was completely clogged), but it quickly ran out of fuel, so I replaced the in-line, fuel pump and in-carb filters and now it doesn't get any fuel to the carb. I removed the line from the pump to carb and it is clean The in-line filter fills with gas as soon as I crank it over, but nothing comes out of the tube at the carb end (I ran clear tubing to a catch bottle).
Since the filter before the pump filled, I assume that the pump is good, but should I replace it?
