boeing707100
- Mar 3, 2012
- 6
Hello! I am new to iBoats.
I have a 1957 Johnson CD-14 5.5 HP that I'm trying to put back into service. It's really in pretty nice shape. I've carefully replaced the points, coils, condensers and spark plugs. I set the points using the factory timing tool and an analog multimeter. I've rebuilt the carb, replacing the worn high-speed needle. I resealed the gearcase with a new water pump impeller. I removed the cylinder head, and scrubbed off the carbon from the head and pistons. I removed the exhaust cover and scrubbed out the carbon. New gaskets for the powerhead.
Here's the problem: It runs like CRAP. I've got fresh gas with BRP TC-W3 XD-50 oil, 25:1 mix. It's hard to start, and when it finally does, it acts like it's REALLY flooded. After I run it, it has 2-cycle oil streaming down the inside of the lower unit for days - emptying onto the floor.
I thought that it might be the reed valves, but I they look okay to me. No cracks.
I like to think of myself as a meticulous mechanic. But obviously I'm not that good because I can't figure this thing out.
I'm hoping that somebody else on here will know this thing better than me and give me some guidance.
Thank you!
Thank you!
