Loop_Dad
- May 29, 2012
- 103
I had my second leak on my inflatable this weekend. It appears to happen because I jammed it into a tight spot in my car. I noticed a slow lead while I was preparing to launch. There were two pin holes. It was leaking in the speed that in 10 minutes, I was able to tell it was deflating. It was big enough that I was able to hear where hiss sounds was coming from.
I had crazy glue for my fishing and had some duct tape. I deflated, used the glue in the pin holes and covered with duct tape. It held the air fine. After 30 min on the water (lake), I noticed that chamber was slowly leaking. I kept pumping every 30 minutes while I fished and it was okay.
What do you folks carry as far as repair kit that you can use while you are out?
