jimrockireland
- Jul 8, 2013
- 141
I have a 1983 Mercruiser 305 V8 MCM228 engine with serial#6285627. I'm trying to bring it back to life after sitting 2 years. The oil filter I removed was a QUICKSILVER 35-802885Q. The dealer wanted to give me a 35-866340Q03. It was shorter than the one I took off so I ended up with one a little longer - an ACDelco PF1218. Is this compatible?
My general repair manual says these engines should use SAE40 (above 70 degrees) and specifically says not to use multiviscosity oils. The dealer suggested I use a multiviscosity 25-40. I don't have an owner's manual and it seems they are no longer available. What is the recommended oil and filter for this engine?
