I'm in the process of repainting my aluminum boat and found a small hole about 1/8 inch in bottom.I guess I found that slow leak I had.Does anyone know what would be the best way to repair this?
No. Nobody knows. Everybody does have opinions and almost all of them work.I would braze it with special rods that can be used with propane torch or MAPP torch.
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
I think I would just drill it out till its clean and put an appropriate size rivet in it with some goop on it, even a closed end pop rivet would work. bonding doesnt really like the way aluminum is flexible.
Originally posted by Speedwagon: Could always take the boat to a welder, and have them weld it closed I'd imagine.
While this is Generally True,.......I've run accross Many small rowboat size boats that have an Alloy with Too Much Magnesium in it..........We Tried to weld 1,.............And,.... It turned into the BIGGEST Bon-Fire You've Ever Seen...............A 14' 4th of July Sparkler
__________________ Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
Princess Auto carries them under the Bernz-o-Matic name. You need a lot of heat to make them flow, but when they do they work great. There's one in Moncton if you're anywhere near it. MAPP gas helps a lot, and if you were doing something heavy pre-heating it in the toaster oven or BBQ is a good idea.For a thin skin on a boat, mapp will work fine and propane might too. Clean the aluminium really well with sand paper to get to fresh metal before you use it. It doesn't stick to the anodized layer so that will have to come off.I don't think I ever saw them at Canadian Tire.Durafix.com will send them to you too. Same thing really.
I purchased some of those low temp. aluminum brazing rods.Just used a propane torch and these rods work great.Took a few minutes to get use to but when you do,you'll fix anything made of aluminum.Good permanent repair for holes in aluminum boats.thanks for all the help.
We have a 12ft aluminum for duck hunting. We have used the repair kit for cabelas its a little green stick you melt and smear on after its sanded well. Anyway it has lasted 5 years+ of use . and cost about 10 bucks,, It usually can be found at the local hardware store also its alot like JB WeldGood Luck
Originally posted by garrett61: We have a 12ft aluminum for duck hunting. We have used the repair kit for cabelas its a little green stick you melt and smear on after its sanded well. Anyway it has lasted 5 years+ of use . and cost about 10 bucks,, It usually can be found at the local hardware store also its alot like JB WeldGood Luck
I've also used the Cabelas kit and it worked great!
