Re: fuel leaks
Ive seen loads of aftermarket fuel fittings not sealing on the engine side of fuel pipe, and on the tank side as well.
im sure youl find a genuine fitting will do the trick as i think the omc gang made everything that little tiny bit different to keep
us all buy genuine spares.
genuine fuel side of things aint a bad idea, the original stuff does last that little bit longer and is worth it in the end.
and dont for get
Fuel leaking is very dangerous, it can lead to massive wallet shrinkage due to todays high fuel prices, this can cause severe
depression and more beer drinking days.!!!!!!!
You can get so fed up with money just oozing from your wallet,that it makes you wanna just sit and cry.
oh yeah and very easy to catch fire as well.
phill
