Re: 97 Johnson 115hp system monitor
the 1997 warning system, will sound for 4 different problems( only three for V4 motors!) low oil pressure to the fuel pump. Low oil in the tank, overheat condition, and for V6 engines fuel restriction. a light will light up for each specific issue. for all the lights to light up after you have reached at least 1000 rpm, then that would indicate you have all four problems( not possible with your V4). Id say you probably have a bad guage( tach). the 1997 guage only sounds at 10 second intervals...previous year gauges would have a pattern for the warning hon to specify what the issue was... for 1997 they have a 10 second sound for all plus the corresponding light would light up on the gauge...to signify what the problem was!!! so with mix and match components certainly possible after all these years, we might not the configuration of your set up. good luck...id check the guage for sure.... the system has a diagnostic mode, but it isn't something easily explained here...bob
