I was on the water for about an hour yesterday, pulled into a cove for some swimming & killed my engine. When I tried to fire it back up (about 1 hr later), it wouldn't turn over at first. I thought it was my batteries or starter ... checked the voltages, and they seemed normal (I charged them the night before). I took the plug out of cylinder number 5, and it was clean.
I should first say that I just installed this engine, and this was my 2nd time out with it. The previous engine was a V6, so is the additional weight of the 350 bringing the transom down enough to let water up the Y-Pipe?
After a couple of cranks, the engine started to turn over, but VERY slowly. A short blast of starting fluid made it turn over a little quicker, and it eventually started back up. But it sounded much different, quiet but rough, almost like it was running on only 4 or 6 cylinders. About a minute later and it began to run smoothly, and sound normal. My best guess is that I need riser extensions ... and I got some water pushed up through the exhaust.
The motor is a 1997 350, Vortec heads, SEI 116 (Alpha 1 Clone) Outdrive. Block is a Chevy L31 Long Block. Edelbrock 1409 Carb w/ Elec Choke, Edelbrock Performer RPM intake, Carter Elec fuel pump.
Thank for any help!
Thank for any help!
