I have a 1986 75hp Mercury that will only start if I pump the primer bulb so tight that I hear fuel spew at the carbs and the bulb softens.The motor may run fine the rest of the day or 5 minutes.If I choke it,the motor seems to try to idle up.This has been ongoing problem and I've replaced the hoses,primer bulb,fuel pump,and cleaned the carb with new carb kits added.It seems to be worse if I trim the motor up much. Pump the bulb until it spews at carbs and it'll do fine again.Any advice or input will be greatly appreciated.
