I changed the impeller and when I was refilling the gear oil it is leaking out a hole where normally water drains just below where the upper and lower units join???? HELP. Did I damage something?
Re: What have I done? Gear oil leaking out before level reaches vent hole
thanks for the replies. I was not even aware there was a seal there?? I will have to look. That seems to be where it is leaking from. At least that side according to the exploded view of the lower unit I just looked at.
