I have a '97 Larson with a Volvo Penta DP-C1 1.95 drive.
I removed the drive and replaced the steering bushings this spring. During reassembly, I unknowingly damaged the ujoint bellows. The boat first ran fine, but after about 85 gallons of gas (no hour meter) began to make a rumble during turns. Going straight and trimmed up a bit, the boat is quiet.
I decided to remove the drive and investigate the u joints. During drive removal, I discovered a significant amount of river water in the u joint bellows section and that I had slightly torn the bellows during reassembly.
The ujoints do not seem crunchy/sticky, but feel smooth. Maybe this is because the weight of the fork/intermediate sections are hiding the wear that was causing the rumble?
At this point, I think I should replace the ujoints, drive oil, bellow, and bellow hose clamps. It looks like the drive side ujoint does not have clearance to remove without removing the ujoint from the double bearing box. The workshop manual seems to suggest that it has to all be taken apart to replace the ujoints. Is this true?
If so, it looks like I need to also replace the 854201 screw, 853484 Pretensioning sleeve, 839253 sealing ring, and the 956000 Oring?
Lastly, I read that the u joint cross refference is a precision 344. Can you confirm that I have that right?
Thanks so much,
Bradley Price
Thanks so much,
Bradley Price
