So I've had this ongoing issue during the last half dozen outings or so. After running for about 45 mins the engine will start backfiring through the carb. If I keep the RPMs below 2600 it won't do it but if I try to run at my normal cruising speed (3000 RPM) it will start to spit, sputter and back fire.
Yesterday I was able to have someone take a look in the engine compartment while it was happening and we noticed that there was a little bit of water seeping out the port side exhaust tower where two pieces come together as if there is a bad seal. It only leaks at the higher RPM's.
We have swapped the ICM, fuel pump, and plugs. Oil is clean, oil pressure runs normal, and temp runs normal. Looking for any information that may help solving this issue.
Enging is an 86 Mercruiser 4.3LX.
