Ki Ki
- Jul 12, 2010
- 292
So the engine has run great so far. Question is, we are not sure when the water impeller was last replaced and Inread this should be done every few years...
It's a 1995 Johnson 30 hp electric start with a good stream of water out of it. Is it necessary if its got a good stream? I'd do it when the mechanic winterizes it.
Also, if we do, how much should a mechanic charge roughly?
Any other routine maintenance we should have done as new owners to this motor if its running well?
