86 merc 140 3.0
Its been ruining ok just rough idle when cold and some hesitation on acceleration. so I decided to check timing but if it try to put it at 6 deg BTDC It wont run It seams to idle and start best when the timing mark is straight up 12 o'clock that's like 40 degrees BTDC!
Could the crank pulley be installed wrong? it has a key-way right?
