james__12345
- Jun 26, 2012
- 196
I have a 16 foot lonestar mod v aluminum boat, with an 1968 18 horse evinrude on it. According to the formulas I've found for determining prop slip the theoretical top speed for this motor is a little over 24 mph. I'm only getting about 17 out of it. I also read that 10 percent slip is a decent expectation but mine is closer to 30 percent.
The prop is brand new, the motor is running about 4400 rpm. I have noticed that the trim isn't quite right. Even using the furthest out hole on the motor, it is still trimmed in quite a bit too much. If I had to guess the motor needs to go out so that she leg is about 3 inches further away from the hull, at the very bottom of the hull. My question is how much of a difference would getting the trim set right make in my speed? I'm not sure how to go about fixing it just yet, but I'd like to have some idea how much difference it would make before I go through the trouble.
