SHickey
- Apr 29, 2011
- 237
Hello,
I have a '87 Blue fin with a 2.3 Cobra OD. Currently I am running a 13.25 X17 aluminum prop ( mfg recommended) but I could not get any top end out if the set up. To make a long story longer, I discovered the LU was changed out and did not have the recommended gearing 2:1 and has gearing most likely for a 5.0 more like 1.59:1.
I am not in the position to change out the LU with the proper gearing and was hoping someone could recommend a different prop size so that I can run at higher RPM with out laboring the motor.
I am thinking of going to a lower pitch like 15 but I was also wondering if I should reduce the diam slightly if I am going to buy a new prop anyway.
Current top speed is 31 MPH at 4500 trimmed out and no speed increase from 4500-5000 except for a lot of motor laboring.
Any help would be most appreciated.
SH
SH
