Expidia
- Aug 26, 2006
- 2,328
My daughter called me early Mon that when she reached the lake after trailering her 25 merc 2 stroke turned over but would not start. I said you probably flooded it choking it and trying to start it after the 1 hour ride with a black motor housing and it was 9am and already 85 degrees out.
As luck would have it there was a guy at the launch from a local boat shop and he suggested to her to push the throttle all the way forward and then try it again as that de-floods the outboard. It worked! I wish I could have remembered that as it slipped my mind since my merc model has an automatic choke.
So remember on hot days you may not need to immediately apply the choke if your model has one. And if you flood it push the throttle handle all the way forward then crank it. She actually thought of that herself but thought the boat would possibly take off if it started with the throttle in the full forward position.
She also was not using her trailering cover, so I suggested she at least use the outboard cover to keep the sun off it. This also stops flying rocks off some trucks rear tires on the highway from chipping the housing
