WinnerCobra
- Jul 17, 2013
- 29
So we just recently bought a new (used) boat, (winner cobra?) model number on the boat is 701536 WH, if anyone can fill me in there it would be great as im not sure of the year. The motor is a 1970 60hp Evinrude which is currently running (just not great). I have changed the spark plugs out, cleaned out the 3 carbs and fiddled with the fuel as far as lean and rich. in neutral it runs excellent you can hear it purr like it did in 70 first year on the lake, but as soon as were in water and throttle up it sounds really bogged down, we cant even get it up on a good plane im sure a 60hp motor is more then enough to push this boat pretty quick, i have messed with all i have knowledge of. Compression is good in all three cylinders were getting about 110psi even on all 3. if anyone has suggestion to get this thing running great all thoughts would be great. also sea foam? was told i should definately run it through so ill be giving that a try tonight.
one last thing is i was told my prop may be too deep for the boat? not quite sure what that means. I am a mechanic (on land) i have decent knowledge of engines, but boats are a whole new deal for me. all help is welcomed!
