Re: Help replacing Rotor in 1967 Mercury 950 SS Please
On this model it(rotor) is removable with the special rotor puller pliers part # 91-32477A1...
I beg to differ! This is not the old-style dual-point distributor model, it's old-style electronic ignition with a "horseshoe" shaped trigger (same as used in some Mercruisers), and a short distributor/rotor shaft, with the rotor bonded to the shaft.
The distributor diagram and instructions posted previously are for the newer-style trigger and not applicable to this ignition system.
Here's a link to the diagram and parts list for the 950-SS electronic ign:
Mercury Marine 950 (6 CYL.) DISTRIBUTOR ASSEMBLY, COMPLETE (MERC 950E-SS-1) Parts
(4) 1/4-20 bolts hold the distributor trigger/rotor housing assy to the distributor drive. Once the housing is dropped, remove the screws (with Nylock nuts) holding the distributor cap adapter (part #10) to the distributor housing base (part #1).
Be sure to note the orientation of the parts, it may help you get it back together later. As I recall, once you split everything apart, the trigger (7) unscrews from the base. The trigger holds the rotor and its bearing into the housing.
Note the trigger shim (6), wavy washer (2) which goes between the ball bearing (3) and the cavity in the base. It provides a bit of pre-load to the bearing so it doesn't tend to move up and down in the housing.
Retaining clip (4) holds the bearing to the rotor shaft assy. It's a slip-fit as I recall.
To reiterate, the rotor is not removable from the shaft assy; it's integrally cast. I can't recall if the "chopper" disk is removable, maybe once the bearing is pulled, but I'd have to take a look at one, it's been a while. Probably not, since they list different rotor assy's for the 4-cyl and 6-cylinder.
So, if you try and separate the rotor from the shaft, you'll destroy it!
The rotor assy is NLA but the guys in the above link still have 2 in stock for only $125 each!
Here's a new 393-2921A 7 rotor assy on eBay for $80 shipped:
New Mercury Mercruiser Force Quicksilver Rotor Shaft Assembly 393 2921A7 | eBay
I would contact the seller and ask for a picture, just to be sure.
HTH & let us know how it goes.........ed
p.s. it might be a good idea to post a pic of the rotor assy you ordered/received, along with the old rotor assy. Maybe we can figure out what's the issue with the end-of-the-shaft. Whatever you've got has to be able to engage the upper portion of the distributor drive (the part driven by the timing belt).
