Hi, I'm a new member here and thought I might ask this rather unique question.
I have a glastron sx 175 3.0l 2005 I believe and the engine will over heat when you pull a tube or a skier. The engine temp has always sat at 150f at idle and when full out, but once you hook up the tube, the temp goes up to 200f within a minute and the warning sound comes on. When I was behind on the tube, it seemed as if the engine sounded a little more growly or raw, but the driver in the boat cannot identify the sound difference.
I just replaced the impeller last year, because it is recommended that you do it every so often and I'm puzzled as to what the problem could be.
Thanks!
Oh and a side note, this boat/engine seems to be very loud in general and sounds the same on other boats that have the same SA Volvo drive. Anybody know why that is/how to dampen the noise?
Thanks!
