U-joint bellows orientation?
thumpar
I am installing new bellows The U-joint bellows at one end have a flat edge. Do those go vertical at the outdrive side? Also, should the water input tube be install before or after the U-joint bellows?
TIA
pn
Re: U-joint bellows orientation?
never done this before but my bellows are marked top.
slag
TIA
They go horizontal IIRC so there is clearance for the water tube and clamp. I put the tube on first, it can be a real pita.
