I picked up a skiff with a 92' Johnson 48 spl 2-stroke. Motor hasn't been started in 5 years. Serviced the lower end and plugs. Was able to start it and it ran fine. Ran the engine for about two hours at at different speeds not exceeding 2500 RPM. Check thermostat operation runs below 140 deg.
Now here is when it gets interesting, when I exceeded 3k rpms the engine went into free running at a very high rpm. Throttling down to idle had no impact and neither shutting the key switch or pulling the safety lanyard. I ran back to the outboard and yanked both spark plugs which did not do anything. The motor just kept running at a very high rpm.....I thought the motor was gonna blow. I then yanked the fuel line out and loosened the cover for the fuel pump to bleed the remaining fuel....it just kept running. I then went to carbs and tried to block the air intakes no luck. I then moved the lever that controls the choke plates and that killed the engine.
Fortunately no catastrophic damage, but definitely unnerving.... What if I was out on the water and this happens....scary!
Any thoughts on where to look.....appreciate any feedback!
