Hi All
I assume the integration of the deck/keel/hull is integral to the strength of hull itself due to the profile created by these parts, being a sideways closed "H" or "I" beam profile (i.e commonly used to strengthen structures), so I'm a bit reluctant to modify this section of the boat without getting some opinions.
I?d like to access the space under the deck periodically and I was wondering if there's a tried and true method to secure the deck to the sides of the hull other than the current, slightly permanent fiberglass tabbed in method? Possibly utilizing a combination of screws / fiber glassed in screw wood strip or fiberglass embedded T-nuts and tongue and groove system? The boat is a Glastron CV16 and the 30? wide deck is tabbed into the 2nd strake on either side of the keel.
All responses appreciated
