Engine runs great about half the time. Other half time it bogs down and will die when going to full throttle.
I decided to clean carbs, but for starters I can't find a socket that will fit on the nut, there's no room for the socket body.
Can someone help educate me a little on the carb set up? It appears the top carb is set up different than the rest. The drain from the bowl goes to a solenoid and then to some hose that I can't figure out where it goes. When I prime the fuel line with engine not running, fuel will come out of the top carb. After engine starts it does not come out, even when the engine bogs down.
I'm guessing this top carb only kicks in at full throttle. Also the bottom 2 carbs have a needle jet but the top carb does not.
The hose from the solenoid to the other larger hose has been removed in the pic. It was tore at the end.
