TERRYCLARK
- Feb 29, 2012
- 27
I have a '89 75HP Mariner that did not want to start when I went to put it on the trailer after being on the lake. I thought it was flooded ( had just switched tanks ) or the plugs were fouled, so when I got home I pull a plug to check and then noticed the wires were looking a little rough. I pulled a plug wire off the coil and the end came off and then another. I just figured I would buy new wires, so I called and the local shop, they said $75 for 3 plug wires ( about 8" long ) I'm still in shock, are they gold plated or what. Why can you not use automotive plug wires?
