Re: No Audible Alarm on Boat, where do I Get it?
Got a crick in my neck getting inside the center console to follow the wires, it's a mess down there. Will have to organize the wiring when I get the engine functioning right. Here's what I found:
The tan wire coming from the engine harness is disconnected at the center console end, it has a female spade fitting at the end and it is not connected to anything. Same goes for the purple wire, it comes from the harness to the console and has a female spade at the end with a second purple wire both crimped to the spade. The purple wire spade is not attached to anything, and the second crimped purple wire goes from there to the starter switch (sorry, can't reach it to see which terminal of the starter it is), and from the same switch terminal, another purple wire goes out to a three pole female plug connector, which has no male connected to it, it is connected to nothing. That purple wire goes to that female plug connector which is composed of three wires the purple, a black, and a gray on one side and the three pole female plug connector on the other end.
