Im having trouble with cavitation eating away at my props. The current prop only has about 20 hours on it, and has streaks where the paint has come off and you can see slight pitting in the aluminum. It has the exact same pattern on all blades so I know its not just paint coming off in one spot. What can I do to prevent this?
Boat is a maxum 2100SR with newer 5.7, pro is a powertech 14 1/2x19 3 blade aluminum prop. I have had 1 other powertech props do this on this boat, and then one Michigan that seemed to hold up fine. On another boat I used a powertech 2 years without problems. Is it possible the powertech blade design different enough to cause the problem with this boat. Any experience?
