Greetings
I damaged one of my carb bodies during a rebuild
It was the upper carb on a 85193H
I purchased a set of carbs of the interweb that supposedly interchanged from a Johnson 1972 85HP
There are some significant differences
Original body SOP# 314948
Replacement SOP# 317472-D2
-Idle mixture screws were long on the original and short on the replacement
-Extra access to passages (threaded plugs Vs permanent plug on the new Vs the old and the upper)
-The reliefs in the top of the new carb are triangular and match the gasket on the float chamber which appears to be the same float chamber on either carb
My plan was to just one of the new carbs(upper) and rebuild and keep the lower but change the low speed mixture screws to all long style
Any clue if this will work?
In the pictures the "new" carb is in the foreground.
Thank you
RED
Thank you
RED
