Rattle from drive when revved in neutral or hard take off in gear.
2tirefire
After PDS bearing replacement I developed a rattle that sounds like its from the drive or Flywheel housing. At first it was only in neutral when I would give the motor a quick Rev, but now its giving a quick rattle when taking off from a stop. Also developed a vibration when turning left or right when under power, U joints????. Pulling the gearbox now to have a look. When I pulled the drain plug there was a few shavings on magnet. Drive oil came out looking brand new but has only had 10 hours on since change.
Any advise on what to look for would be greatly appreciated.
DP-A, Single bearing Flywheel housing.
First Picture of boat actually in the water.
Don S
Re: Rattle from drive when revved in neutral or hard take off in gear.
Metal "Shavings" on the magnet is not good. A black goo is normal, but nothing shiny.
2tirefire
There was also the black goo. There was 3 little specs that I could see.
Don S
It could also be the flex plate bolted to the flywheel (spings coming loose). That's one reason I dislike just pulling the shaft to replace the bearing. If the flex plate is damaged you have no way of inspecting it. If the bearing or bushing in the crankshaft pulls out, it really goes downhill fast.
2tirefire
Is there a function for these springs, this rattle was not apparent prior to bearing replacement?
Don S
The flex plate is also known as a vibration damper. When they get rusty from water getting through the bearing, they tend to fail, come loose and can rattle.
Here is a picture of a typical flex plate/vibration damper.
2tirefire
Thank you for the picture Don. I'm going to use my inspection camera to see if I can see any damage.
bruceb58
We had a flex plate crack on a 270 drive in a boat we owned. Sounds like identical issue you have.
2tirefire
Bruce what were your symptoms? Wonder if the vibration I'm feeling is related to the rattle?
bruceb58
Felt like bad u-joints. After replacing u-joints, next step was looking at flex plate.
2tirefire
Exactly what I'm feeling, thanks for your time Don and Bruce. Will update when I find problem.
2tirefire
After pulling PDS(forgot how much of a pita is was to get the last c clip) I used my inspection camera and all springs are in place and it looks like there is no signs of rust anywhere.
Should I go ahead and replace u joints? If so is a automotive u joint replacement u joint satisfactory?
bruceb58
Need to look for cracks in the plate.
2tirefire
Could not locate any cracks in flexplate. Spent a good hour inspecting with camera. Also having troubles finding U joints that cross over to automotive for my application. Does anybody happen to have that information. It would be greatly appreciated.
