I have a 1988 4 Winns 350 with an Ac Delco
distributor and an ESA set up. I have adjusted
the ESA as best as I can, but reverse is still giving
me a problem. When it shifts into reverse, it stalls
and comes out of gear into neutral hard. Would it be the
lower cable on the engine bracket, or the upper cable that
I should take 1 or 2 turns on the block on the cable, then try it?
Also, is it as simple as putting the 2 wires together that go to the
ESA to eliminate the system? The engine idles low, so I would like to try it
without the ESA .
Thank you, John
without the ESA .
Thank you, John
