I have a mid 90?s javelin fish and ski boat that had a 150 Johnson with oil injection. I put the motor on another boat and installed an older 140 Evinrude in its place. The wiring harness to the engine was an exact match and the only wiring I had to modify was for the trim. Got it working fine.
I took it out for the first time today and the alarm on the boat went off with rapid beeps, which the tag said is ?no oil?. I have removed the oil reservoir from the boat and as I remember, there wasn?t any other wiring that went to the oil system. There was a connection between the original motor and the oil system but both of them are gone.
At this point I?ve got a regular older 2 stroke where I mix the oil and gas, and a boat wired for an oil injection system. How can I disconnect the oil alarm without disturbing the temperature sensor system?
