Saw the wires poking out of my control cables sheathing about to put a hole in my fuel line. I cut back a bit of the sheathing and saw the inner plastic sheathing over the control wire all busted up. Put some zip ties over the outer wires and this morning when I went out fishing it wouldn't idle down after starting. I had to cut some of the zip ties to relieve pressure on the exposed inter wire. Anyway, I'm looking to replace my control cables and was wondering if anyone has done this and if so, what length did you use on a 16' SS? The ones that are on it now, look a bit long. They smash up against the top of the splash well when tilting the motor up. Not sure if it's relevant, but I'm running a Yamaha 70HP with Yamaha 703 Controls. I'll pull mine and measure them, just wanted to compare with others.
