Hi I have a 1994 SeaRay Sundancer 230, with a 5.0 L Mercruiser engine (carburetor) and I have a problem. When I start the boat and slowly accelerate to 1200 rpm, it cuts out completely and stalls. If I throttle up quickly, I can get it past 1200 rpm up to its max, about 3200 rpm. As I throttle down, the engine slows until it gets to about 1200 rpm and then it cuts out and stalls again. I'm able to restart it immediately, sometimes needing a little throttle. This has happened while in gear on my way home yesterday, as well as today (never left marina). Also happens when using throttle only. I have tried adding some fuel injector/high octane cleaner. I have also tried spraying the linkage and the throat of the carburetor w carb cleaner.
Thanks for your help-
JM
JM
