Last week I fired up the boat and discovered it would barely run. (Chrysler 55 hp w std ignition & alternator) I pulled the flywheel and discovered the points to be very dirty and corroded. I tried to find a new set however, the local sources around me stated they were discontinued and no longer available. (which means "they are old and they don't want to bother")
Because I could not find new points, I pulled a set off a donor 45 hp Chrysler which were exactly the same. So I cleaned and installed them. (gapped to .020 with a feeler gage) Despite doing this the motor did not run any better. After getting online, I discovered the points on my motor were incorrect and they were for a magneto ignition system which is different from the std ignition points. I have since ordered the right set of points online.
Does anyone know if using the magneto points on a std ignition will throw the timing off?
