Re: 1976 85 hp neutral
Doesn't that model have a shift rod that's threaded on its top and has a barrel type part screwed down on it? If so, simply screw that barrel all the way down, then back it off just until it faces properly.
Note that the white nylon bushing must be present in the hole in that barrel, otherwise it will be impossible to have the engine shifting properly.
