Celtichawk
- May 6, 2012
- 564
That is a ballast resistor. It gets 12 volts in on one terminal from the ignition switch and the other terminal goes to the coil positive terminal. IT is for an externally resisited coil, the most common type of ignition system coil "back then".
My descriptuion of it relates to how the boat left the factory when it was new, who knows what happened afer that :suspicious:.
A bypassed ballast resistor does not necessarily mean electronic ignition though. Maybe a resistor wire was substituted. Maybe it was just bypassed totally for an internally ballasted coil. Maybe it was bypassed because it failed. And many electronic triggers that replace points use all the stock components like ballast and coils.
Yours is what it is and I for one await the results of your investigation :ranger:.
Are you having problems or did you just see this component and wonder what it was?
Per a diagram recently posted elsewhere, that ballast resistor block had one wire coming from the ignition switch with two wires connected to the outlet side. One of the two came from the momentary 12v terminal on the starter solenoid and the other went on to the coil. Once the motor was running, the lead from the solenoid would be dead (or just reflect the reduced voltage) and the other, going to the coil would show the ballasted voltage.
If your motor starts and runs, then they undoubtedly bypassed the ballast resistor with the ignition lead and abandoned the temporary 12v lead coming from the solenoid.(actually they could have left that solenoid lead tied into the ignition lead and it would make no difference.
Now the question remains, is your coil suitable for a full 12v's? It will run extra hot (until it fails) if not. Also, are you using an electronic trigger as opposed to points. Most all Electronic triggers that I am aware of do require a full, constant 12 volts, Pertronix included.
That is assuming that you have the low profile electric shift. If you have the high profile outdrive, all bets are off.
How would I know about this? I'm pretty sure it is electric shift and also how would I know for sure?
Post a picture of the drive. We'll tell you.
Unless someone already did a conversion, a '72 could only be an electric shift. Also, I hope you 'lnow for sure' because it matters what type of fluid you use in the lower drive.
I am almost willing to bet that with a 25' SeaRay, you have the high profile drive.
Okay I will take photos today! I have not swapped any oil in drive yet so with that being said with my questions will help determine which drive I have and then you guys can assist with tellin me the oil type
