TOP1PERFORMER
- Jul 13, 2013
- 21
I have a 1987 Evinrude 88 SPL. Picked up a plastic bag over the water inlet when cruising. Stopped just before major damage but lower rubber exhaust housing seal started to burn through. Replaced everything at the bottom end including water pump and when running notice some water running out at top front of mid section during fast idle. Need to replace the upper rubber water tube grommet at the top of the mid section. What is the procedure? Can it be done without removing the powerhead? Not sure if the top seal of the inner exhaust housing needs to be replaced. Thanks
