I have a 1978 140 HP OMC stringer boat. The carburetor is a two barrel rochester 2GC, model 7040083. Does anyone know the correct idle adjustment procedure for this carb? The boat seems to fire fine, but won't continue to run without giving it some gas. I had the carb apart and readjusted the float, and this seemed to help the problem somewhat, but i believe the idle is still off, as it won't fire and continue to run well until it is very warm. The idle adjustment needle valves are set around 3/4 and 1 turn, which according to the break down book was way lower than the starting point which makes me wonder.
