camcorder44
- Jul 12, 2013
- 3
hey so i was working on my '91 Alpha One Mercruiser lower gear unit to replace the water pump impeller. everything when smoothly with the water pump, however, when i try connecting the lower unit back to the upper housing i have two problems.
the first problem is that i have trouble putting the drive in all the way. i have to wiggle it around and turn the prop (the lower unit is in forward gear) until it finally goes it. but i feel like it takes more effort than normal to get it in there. other videos make it seem like it should slide right in there. i have to wiggle it a lot and push up pretty hard to get it to finally get in there.
once its in there i have problems when the boat is on and attempting to put it into drive. it hear like a light grinding/slipping of gears and the prop doesn't move. also as a side note is the prop supposed to be able to move freely when the motor is off and its in drive. i know its supposed to lock when it spins the opposite way, but when spinning it toward the direction of the gear you are in it clicks a few times each complete rotation. its like there is resistance back and once you've passed it it goes for a little and starts again.
any idea??!?!?! PLEASE NEED THIS RESOLVED ASAP!!!!!
