buddhapi
- Jul 14, 2009
- 159
this was my first lower unit I tore into, and I thought it would be perfect......this lower unit has the split case. I did get it all back together and moved the shift rod up and down and everything seemed to work great. today, I bolted the lower unit up to the rest, and I don't have forward gear. I have neutral and reverse. I can shift it all the way forward, but the prop shaft free wheels just like neutral.
#1 question is: how many different length brass shift connectors does Evinrude use?
#2 """" did I do something wrong in the lower unit? it did shift fine before the bolt up. I put in a 6 inch brass connector. same as the broken one the customer brought me, but I got this unit as a basket case; Greg
