I bought a 69 evinrude sweet 16 with a 75 hp 1975-1976 Chrysler motor. Took it out on the lake and it started fine. I immediately noticed the speed was very low, the engine would rev higher but gain no speed my top speed from the start was near 5 mph. Before long i was barely moving. I asked around and received feedback that it was the prop slipping. I had a spare two blade prop and it started out with good speed after cruising around for fifteen minutes I slowly lost speed and by the end of the day i could only go 5 mph at high rpm's. I believe this prop was slipping too. I examined the hub and the rubber fitting was worn on both props. It is a 13- 21 prop with 18 splines. I found that the original prop on the motor was supposed to be 13 by 17. I am looking for a new prop but i don't really know what props i can use and which ones i can't. Any advice would be appreciated.
