Mercruiser alpha one 4.3 lx solenoid replacement
kareillyjr20
I have a 1995 Chaparral 1930 ss with a mercruiser alpha one 4.3 lx engine. When I start the boat sometimes it doesnt turn over and makes a light thunk. I have replaced the starter and starter solenoid and cleaned all the battery contacts. the battery is fully charged. I just want to make sure that the solenoid is behind the trim pump and if anyone has any suggestions on how to replace it. I have attached a photo. Thanks for the help.
Re: Mercruiser alpha one 4.3 lx solenoid replacement
Ayuh,... Welcome Aboard,... Nope, that's the trim solenoid,...
The slave solenoid will be on the motor,... look for yellow/ red wires,...
Have ya ever pulled the mid/ aft spark plugs when ya get that Thunk, 'n looked for Water in the cylinders,..??
kareillyjr20
Thank you guys for the help. Ill have to pull the plugs once the rain lets up. That diagram is very helpful. Ill have to follow the wire from the stater solenoid to the slave solenoid.
