Hello. I have recently developed a problem with my 1986 OMC 3.0 engine. Engine works fine while testing in the driveway, even when I put it in gear it still gets to the high RPMS but when I put the boat in the water the engine will not get into high RPMS when I put it in gear. The engine still goes into high RMPS when I manually push the cable forward or when just push on the carburetor arm. I have changed the points and adjusted the timing and nothing. Then I installed electronic ignition and still the same problem. The only thing I can think of is that I did change the transom seal before the problem started. Could I mess something up while doing it? I did not take anything apart just pulled the new seal over the outdrive and installed it. I did the same thing a couple of years ago and did not have this problem them. Please advise. Any insight would be very appreciated.
