miskusfish
- Jul 5, 2013
- 2
I just bought a 1987 Bullet Bass boat and was a bit confused about the livewell. It's a beautiful thing but I am unfamiliar with them. The livewell will not drain and came with plugs that are too small for the holes. There are two holes in the tank and a few by the boat drain plug in the back. I tried to push air through the holes with an air compressor but didn't have any luck in getting it to drain. Any ideas?
Also, my boat takes on a lot of water. I'm not sure if I'm supposed to plug the holes in the back by the motor. Does anyone know?
The aerator works well but will this pump water from the lake into the livewell? I don't want to do that since the baitfish that I'm using are very sensitive and need very cold water.
Thanks so much for any help that you can give!
P.S. I've attached pictures
