Hi all, this is my first post, I have a 18' 1984 Sea Arrow 5.0L that I just had the transom replaced. My question: Is there a way to leak test the gimbal seal and bellows without re-installing the motor? I was thinking if I install the exhaust Y pipe and the outdrive and back it into the water while on the trailer I can check for any leaks? Will this work. I just don't want to re-install the engine just to find a water leak and have to remove it yet again.
Thanks
Warren
Thanks
Warren
